Actually, Salt pools seem to operate fine at a FC level of 3-5 ppm even though the CYA is 60-80 ppm. Many posters on this forum with salt pools have reported this.
If you maintain your TA on the low side (about 80 ppm) and maintain your pH at about 7.5-7.6 you will get better pH stability becuase of less outgassing of carbon dioxide.
The filter you are talking about is commonly called a 'fill stick'. You can google that to find out more.
If your well water tests negative for metals then you probably don't need one.
Also, adding borates to 50 ppm has been shown to be helplful in salt pools by reducing santizer demand and stabilizing pH. Search the forum for 'borates'.
Did you have the "Total Control System" installed or just the Autopilot Digital? The Total Control inlcudes and acid tank and pH and ORP controllers to automate pH control and chlorine levels. The Digital will not maintian pH without manual addition of acid to the pool.
