Thread: Busted ball valve?
    Default Busted ball valve?
    Hey, I have a jandy ball valve that broke. It is for the main return on my in- ground pool. There is a pvc pipe that connects the 3 returns valves to the return lines. All three ball valves are on a single pipe. Should I just replace all three or is there a way to get the bad one off the pipe?
    I am not a plummer by any stretch of the imagination .
    Thanks,
    Ed
    Thumbs up Re: Busted ball valve?
    Ed, I'm having a little trouble picturing your set-up. A ball valve is a one way valve and would normally be connected to a 'feed line' by tees or 90s, rather than in 'series' like you describe If you could post a pic, that would be great! It seems to me that with a couple of specialty fittings (which I'll describe, or Poconos has posted a way to make them yourself), you may be able to just replace the one broken valve. I'll keep an eye on this and offer what I can after you respond. I hope that it will be as 'easy' as I imagine and will help all I can! - waste
  1. Busted coping (PVC) on inground pool !!
    By jtnaylor in forum In-Ground Pool Construction and Repair
    Last Post: 09-07-2010, 05:15 PM
  2. Ball Valve Recommendations...
    By jgmcinnis in forum In-Ground Pool Construction and Repair
    Last Post: 07-10-2007, 01:19 AM
  3. Back-wash hose busted.
    By Pool_Mike in forum In-Ground Pool Construction and Repair
    Last Post: 05-21-2007, 01:36 PM
  4. Pump too big for pool, read some posts on reducing flow with ball valve
    Last Post: 06-29-2006, 07:39 PM
  5. ball valve or neverlube for solar lines
    By GTakacs in forum Pool Equipment & Operations
    Last Post: 05-08-2006, 01:37 PM
