Results 1 to 10 of 12
Thread: Pump turnover rate
    waldreps is offline Registered+ Thread Analyst waldreps 0
    Lake Park, MN, USA.
    Default Pump turnover rate
    How can I calculate how long it takes for my pump to turnover the water in my pool? I don't see a GPM rating on my pump only horsepower. Is there some calculation I can do or am I missing something? Thanks.
    Stacy
    duraleigh Guest
    Default Re: Pump turnover rate
    Hi, Stacy,
    You should be able to find the "pump curve" for your model on the manufacturers web site. use 50-60 head for an IG pool. That'll get your prettyclose on gpm for your pool.
    Lake Park, MN, USA.
    Ok, here's the deal....I have an AO Smith motor using a Hayward Super Pump strainer and impeller. Should I just assume that the AO Smith motor is an exact replacement for the original Hayward motor and look at the Hayward info? The motor was replaced before I bought the house.
    mas985's Avatar
    Pleasanton, CA
    This is the third thread on this topic and probably deserves a sticky but anyway here is what I posted on the other threads:
    Turnover is the time it takes for the volume of the pool to run through the pump. However, this does not mean that all of the water has gone through the pump. Some water goes through once, some twice and some not at all. It depends on the plumbing, returns, skimmers and drains. To determine turnover:
    First, determine the head loss for your plumbing. A rough estimate is to take your PSI from the filter and multiply this by 2.31. If you do not have a vacuum gauge, add about 10' of head for suction head. Otherwise, multiple the vacuum (in. mg.) by 1.13 to get suction head. Add return head and suction head to get total head.
    Second, look up the the flow rate from the pump head curve. Usually in the pump manual.
    Third, use the formula turnover (hrs) = Pool Volume (gallons) / (gpm * 60)
    Also, you should be able to find the pump curve on the Hayward site.
    Mark
    Lake Park, MN, USA.
    Thanks for the info, that's what I needed. According to those figures and my numbers, looks like my pump needs to run close to 24/7 to turnover the water twice each day as I have heard is recommended. Thanks.
    Scottsdale, Arizona
    Twice a day turnover does not sound right ..
  1. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 12:22 PM
  2. AGP and 1hp Pump... Calculate Turnover?
    By Solarius99 in forum Pool Equipment & Operations
    Last Post: 06-20-2011, 08:53 PM
  3. Pump Rate
    By iwannapool in forum Pool Equipment & Operations
    Last Post: 06-22-2007, 06:38 PM
  4. Turnover rate per day/Pump run time and GPM
    By 26theone in forum Pool Equipment & Operations
    Last Post: 03-10-2007, 01:52 PM
  5. Two-speed pump flow rate
    By sharkey21 in forum Pool Equipment & Operations
    Last Post: 05-03-2006, 08:18 PM
