Here is a new one.
I have a 25,000 gal IG vinyl pool that is 6 years old. There is a noticable current flow, shock, electic tingle...what ever you want to call it when both feet are in the pool and you touch either the ladder or the aluminum coping.
There is a bond wire that goes all the way around the pool, and is attached to the underwater pool lights, connects with the ladders and is also conected with the pump. The pump sits is a cock, under the decking.
I had the electrician out, he rechecked all of the connections and was getting between 3 and 8 volts at the ladder and the coping.
The shocking continues even when all of the electrical equipment was disconnected. Also, the voltages were the lowest at the lights and motor.
He thinks that stay current from an underground cable or some other source is entering the pool. He offered to evaluate further.
If there is not a malfuntion with my equipment or connections, then is there any cause for conern?
Has anyone else ever heard of this?
