Thread: Tool for the pump basket plug?
    Default Re: Tool for the pump basket plug?
    mine just unscrews by hand...might have to put a pair of pliers on it - carefully.
    Kansas
    Thanks Matt, I had a mental black out there for a moment.
    Guess I should get my husband involved in pool maintence- guys always think of using tools to solve problems where I always have some off the wall round about method ( that never seems to work).
    BTW- I PM'd you about a down & dirty problem...
    Thanks again
    ~Hoffmans
    I PM'd you back - good luck!
  1. stripped plug nut, hayward super pump
    By docsobeck in forum Pool Equipment & Operations
    Last Post: 05-25-2011, 10:12 PM
  2. Help! with blowing out the lines using the pump drain plug!
    By Amir in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-06-2007, 05:16 PM
  3. pump will only prime when basket it out
    By ScottsdaleSwim in forum In-Ground Pool Construction and Repair
    Last Post: 10-23-2006, 10:52 PM
  4. pump will only prime when basket is out
    By ScottsdaleSwim in forum Pool Equipment & Operations
    Last Post: 10-15-2006, 11:01 PM
  5. pump plug- tines form circle-
    By mom2PMPV in forum Above-Ground Pool Construction & Repair
    Last Post: 06-08-2006, 11:35 PM
