Thread: latest results and pool is hard on eyes...
    Default latest results and pool is hard on eyes...
    My eyes are not that comfortable in our pool, not sure why. Here is the latest:
    fc: 1
    cc: 0
    tc: 1
    ph: 7.4
    alk: 50
    cal: 150
    cya: 60
    gallons: 28K
    thinking about:
    14 lbs of baking soda (6 lbs, re-test, then 2lbs re-test until 14)
    25 lbs of calcium
    does this make sense? And why are my eyes smarting? I thought that was related to PH and my PH looks fine...
    tia,
    jd
    Carterville,IL
    Default Re: latest results and pool is hard on eyes...
    Looks like you ALK is low. Should be at least 100-130 ish. I'd do baking soda for sure. Start small and maybe add 8-10 pounds and see what that does in 24 hours.
    30' Esther Williams Classic Granite
    Installed july 2006
    mbar's Avatar
    Ashland, PA
    With a cya of 60 you should have your chlorine at a minimum of 5ppms. With an alkalinity of 50, calcium at 150 and ph at 7.4, your pool is slightly acidic. I would bump the alk up with baking soda, as traceyb said, and it should take your ph up slightly also. If you have a vinyl liner you don't need calcium, but if you have a plaster pool you will have to take your calcium up to 250.
    Northeast PA
  1. My eyes, my eyes
    By shadowman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-09-2008, 07:57 PM
  2. Red eyes
    By PaulE10 in forum Dealing with Alkalinity and Calcium
    Last Post: 09-09-2006, 04:09 PM
  3. what makes eyes sting in the pool?
    By pairadocs in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-21-2006, 02:31 AM
  4. ok these are my latest test results
    By fog80 in forum DPD-FAS based testing
    Last Post: 04-30-2006, 05:16 PM
