Results 1 to 10 of 10
Thread: Canadian looking for salt
    Default Canadian looking for salt
    Anyone know where I can get the salt (cheap) to start up my SWG.
    Pool stores want $32 per 80lbs bag. I apparently need about 350lbs. Is that a reasonable amout to pay?
    16 x 32 IG concrete kidney; ~76,000 litres
    Hayward: Super Pump M/N C48k2N143B1; Pro Series Filter M/N SP714TC; 4.2 chlorine feeder; 6 2'x20' sungrabber solar panels with separate pump
    Default Re: Canadian looking for salt
    All you need is plain solar salt that is used in water softeners. It is 99.5% pure. You can also use the pellets but they take much longer to dissolve. It's usally 99.8% pure. Just make sure it has no additives for iron removal or anything added to clean the softener. It should be much less expensive than pool salt, which is usually just solar salt that is gound up finer.
    salinda is offline Lifetime Member Weir Watcher salinda 0
    San Jose, CA
    I would just add that in the US, this is the salt you see in large bags up near the register in any grocery store. It is also sold at hardware stores.
    Salinda
    Ontario.
    I haven't seen the term "solar salt" in Ontario. Isn't this the same salt that water softeners use? If so, any hardware store, CTC or big grocery store should have it.
    This is listed on the Canadian Tire at $6 for 20 kilos (44 pounds).
    Sifto Crystal Water Softener Salt
    • Improved resin clean formula
    • Inhibits rust build-up and stains
    • Pure 99.8% evaporated salt
    • High purity brine reduces maintenance
    The purity looks right but I wonder abouth the "resin clean" formula? Do the chemical savvy here have any ideas if that is a no-no additive or just marketing hype?
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    giroup01 is offline Registered+ Thread Analyst giroup01 0
    Canada
    Quote Originally Posted by justawildchild View Post
    Rona, Reno-Depot, Home Depot.
    About $4.00 CDN for 20 kg of water softener salt.
    Reseller of Taylor water-testing products for Canada
    Quote Originally Posted by giroup01 View Post
    Doesn't water softener salt come in crystal form? How long would it take to disolve? Does it come finer?
    Ontario.
    Saw it at today at Home Dopet for $4.70 per 20 kilo, Costco for $4.45.
    Canada
    The salt I used was in pellet form, about an inch long. Threw the stuff in the pool, about 6 bags, jumped in the pool and stirred things up. Took about, maybe half an hour to dissolve.
    That was last year, I don't have an SWG I just wanted to see if I liked the feel of salt water.
    Pool salt will dissove a bit faster than solar salt since the crystal size is smaller. Pellets dissovle slower but they all dissove farily fast so it's really a moot point.
    Ontario.
    Waterbear, any idea wether "Improved resin clean formula" is an additive that should be avoided? One brand has that but the salt is 99.8% evaporated salt?
  1. Aqua Rite low salt reading when salt has been tested high
    By DirtRider67 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-19-2011, 04:58 PM
  2. Canadian Closing
    By Chad-WL in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-21-2006, 08:38 AM
  3. i'm a patriotic canadian but..THIEVES!
    By tenax in forum General Interest
    Last Post: 08-09-2006, 07:31 PM
  4. Canadian Burgers
    By Poconos in forum General Interest
    Last Post: 06-21-2006, 02:19 PM
