Results 1 to 8 of 8
Thread: How to fix cracked valve?
    DFW Texas
    Default Re: How to fix cracked valve?
    I'd try JB Weld or pure silicone caulk.
    IG concrete, 16K gallon, DE, BBB, Polaris 360
    Repairs on a valve should only be considered a temporary measure...the valve should be replaced, IMHO.
    Honesdale PA
    Is gthe valve a generic Home Depot valve or something more expensive? Where is the crack and most important, what causes it to crack? Being on the suction side and the answers to the above questions, you may be able to fix it. But probably as Waterbear said, only temporarily.
    Long Island, NY
    If you happen to have the smelly 2 component pvc glue, you could try to apply this sparingly over the crack. Even CA glue (loctite) might help - for a great selection of CA glues see www.leevalley.com - some are gap filling and have helped me in many repairs around the house.
    But I agree, this should only be a temporary fix. A hose clamp (if it fits where the crack is) might relieve the mechanical stress on the crack - also temporarily.
  1. Waterco F600 top mount multiport valve sand filter - removing the valve
    By wojie24 in forum Pool Equipment & Operations
    Last Post: 10-29-2011, 11:41 PM
  2. Jandy valve ... water getting past closed valve
    By Longgrove in forum Pool Equipment & Operations
    Last Post: 06-13-2011, 02:59 PM
  3. My DE tank cracked.
    By JETTA in forum Above-Ground Pool Construction & Repair
    Last Post: 07-31-2007, 10:38 PM
  4. Cracked sight valve
    By cmcq in forum In-Ground Pool Construction and Repair
    Last Post: 07-22-2007, 02:07 PM
  5. Cracked multiport valve.
    By TfromNC in forum Pool Equipment & Operations
    Last Post: 03-28-2006, 02:34 PM
