Re: Disappearing CYA
You need to get your chlorine up to shock level, and hold it there for a couple of days or you will be fighting algae for the rest of the summer. You can tell the algae is gone if you hold Free Chlorine overnight. There should not be any combined chlorine. I would suggest you invest in a good test kit - one that can test over 5ppms of chlorine. It will be the one of the best investments you can make.
Northeast PA
