Just to add a word to Watermom's advice, I would also bring the alk up to the 120 range. When using trichlor, the higher alk will help keep the pH from swinging so far and so fast. The fact that you had high alk before is probably why you didn't have as much problem controlling your pH as you do now, with lower alk.
