Results 11 to 13 of 13
Thread: bleach in toilet to speed things up
    Honesdale PA
    Default Re: bleach in toilet to speed things up
    May not be anything to worry about but what about the effect of those pucks on the creepies in a septic system?
    joliecharlie is offline ** No working email address ** Thread Analyst joliecharlie 0
    Pinehurst, North Carolina
    Had an in law that washed almost every load of clothes with bleach, cleaned toilets by pouring bleach in them. I think she used bleach for everything and it did cause them septic system problems. Beneficial bacteria that break down the waste are killed by too much bleach. Drop-ins in the toilet aren't enough to do it, but overuse of bleach is.
    We too have had the seals of toilets fail because of drop ins.
    Yeah, those "2000 Flushes" bleach tabs destroyed the flappers every few months and we'd get running toilets. I stopped installing them years ago.
  1. Thought i could speed things up but noooo gooo
    By dansdad in forum DPD-FAS based testing
    Last Post: 06-18-2013, 10:51 AM
  2. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 01:22 PM
  3. Chlorine tablets to clean toilet??
    By huskerfan in forum General Interest
    Last Post: 07-04-2011, 12:55 AM
  4. 2 speed pump. High speed puts sand in pool?
    By mjs31 in forum Pool Equipment & Operations
    Last Post: 08-23-2007, 06:00 PM
  5. Trichlor pucks in toilet bowl?
    By dfarra in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-16-2006, 06:41 PM
