Results 11 to 15 of 15
Thread: For those of you with sand blowing back into the pool....
    Jul 2014
    Madison, WI
    Default Re: For those of you with sand blowing back into the pool....
    New versus old laterals. Slightly different models, as I have an older Triton from the 80's as opposed to the current Triton II.
    26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
    Jul 2014
    Madison, WI
    I suppose this could have happened before I was putting the laterals in, but I think I overtightened the laterals, and... CRACK! There goes the hub...
    Jul 2014
    Madison, WI
    New hub and old hub. Too bad they don't attach the same, but the parts are damn similar for a Pac-Fab Triton from the 80's, versus a current Pentair Triton II.
    Here's what a groove created by sand looks like. This must be the culprit to where sand was blowing back in, though the entire web of lateral spokes were cracked long before I got into the filter yesterday. The spots where it cracked show some aging and wear, as if they'd been there for a while.
    Jun 2014
    Texas
    I believed that my filter was blowing sand, but it was particles my filter was not picking up. I started adding DE to my filter and it has had tremendous results. I followed the recommendations on this site.
    30k gal ell-shaped IG pool with TR100 sand filter.
    Nothing like a cheap, simple fix! DE as an add-in to a sand filter and skimmer socks are my two favorite cheap fixes.
  1. BLowing sand out during backwash?
    By greenwich3 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-08-2012, 09:41 AM
  2. There is sand at the bottom of my above ground pool that keeps coming back.
    By confusedpool in forum Pool Equipment & Operations
    Last Post: 06-16-2012, 02:02 PM
  3. DE blowing back into inground pool
    By markginger in forum Pool Equipment & Operations
    Last Post: 04-15-2012, 04:51 PM
  4. Pump Blowing Filter Sand In Pool???
    By webfeet in forum Pool Equipment & Operations
    Last Post: 03-27-2007, 12:18 PM
  5. Sand blowing through returns
    By TR in forum Pool Equipment & Operations
    Last Post: 05-30-2006, 11:19 AM
