First I hate my Polaris 380 I would like to reuse the pump and connection and finds a working less costly cleaner that actually cleans. Vinyl liner 40K gallon pool.
In 4 years I have repaced
3 reversing units due to cracking because the water pressure and the unit somehow blow out the edge of the plastic near the outlet hole to reverse the unit
3 bags since the velcro gets wasted and now the last one ripped.
The unit no longer climbs the walls or has enough power to make it to the deep end corners probably due to the new crack in the reversing unit.
I have cleaned lubed, sealed everything anyone could imagine, to get this this to fully clean my pool and it always has a new problem. I had one good year and ever since it has been a disaster. last year I had to rebuild the pump and replace all the bearings in addition to the other issues.
OK so I have a working cleaning pump and an outlet. I dont want to spend big bucks on a unit that will just need constant repair, Honestly I spend less time with my pool chemistry that the cleaner. So I can start replacing Polaris parts again or change cleaners.
Anyone have any suggestions for a new in pool dedicated pump cleaner that will use the existing polaris outlet pipe threading and pump?
I need a new one very soon so any suggestions would be apreciated. If you want to diagnose my problem I think I have tried less pressure and many other fixes and nothing has worked so I want to move forward and change brands before I go broke.
George B
