Thread: pump power rating versus electricity consumption
    Oakland, CA
    Default pump power rating versus electricity consumption
    Greetings,
    My pool circulation pump has a 3/4 HP motor. My electric utility (PG&E)
    recently replaced my mechanical meter with a digital one and I can
    see now that running the motor uses up 1.2 kW. Is this normal?
    3/4 HP is about 560 Watt. Even with a 0.8 power factor and another
    10% of losses I should still be under 1 kW. Or perhaps the 3/4 HP
    rating doesn't really mean 3/4 HP?
    Thanks!
    Luigi
    30'x16' (irregular) indoor gunite/plaster pool, 10k gal,
    Autopilot DLG-220 with SC-48 cell, 3/4 HP recirc pump,
    solar panels, heat exchanger from 200 kBTU/hour Viessmann boiler
    mas985's Avatar
    Pleasanton, CA
    Default Re: pump power rating versus electricity consumption
    It depends on your service factor as well. Most high efficiency pumps have fairly high service factor of 1.6 or greater which makes the braking HP (true HP) higher. For a 3/4 HP pump, that is about 1.2 braking HP with a service factor of 1.6. BHP to energy use is about 75%-85% efficiency:
    Kw = BHP * .746 / .75 = 1.2 kw
    So what you are reading is reasonable.
    Mark
    I'm not familiar with the term "service factor". What does this represent and how is it calculated? thanks for any info!!
    mas985's Avatar
    Pleasanton, CA
    Service factor is determined by the motor manufacture and is usually stamped on the motor label along with the horse power. The "labeled" HP is virtually meaningless without taking into account the service factor. The true horse power of a pump (i.e. braking horse power) is the labeled HP times the service factor.
    Mark
    Oakland, CA
    Quote Originally Posted by mas985 View Post
    You are indeed correct. The service factor on my pump is 1.67.
  1. Feeling a little electricity in the pool
    By mirogers1 in forum Pool Equipment & Operations
    Last Post: 04-24-2012, 03:12 PM
  2. No power to pump? Fuse blown. Replaced & didnt fix
    By topnotch in forum Pool Equipment & Operations
    Last Post: 06-27-2011, 11:40 PM
  3. Aquarite Jr. rating
    By cmack in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-18-2006, 10:41 PM
  4. Saving electricity - replacing an old pump/motor
    By pauster in forum Pool Equipment & Operations
    Last Post: 06-08-2006, 08:48 AM
  5. Problem with new Power-Flo LX pump
    By haeffnkr in forum Pool Equipment & Operations
    Last Post: 06-04-2006, 10:17 PM
