Ok, I am using the BBB method as well as some Trichlor pucks. I have better luck holding the FC with higher CYA.
My CYA was 40 before and using about 4 PPM a day of FC.
My PH was getting high and I wanted to bump up the CYA a little so I used the Trichlor pucks to accomplish. I used 15 3 '' tablets and I was under the impression that each had .6 ppm of cya in them hence 15*.6 is about 9 ppm of cya added.
I just tested and my CYA is like 70-75. I tested a few times before and know the cya was about 40. Any body want to take a stab at that?
Is there something else that will throw off the CYA test?
