Thread: Enclosing Heat Pump?
    psciotti Guest
    Default Enclosing Heat Pump?
    I'm running an Aqua Heat Pump and it is noisy. Between the the heat pump, the filter, and my house AC condensers I'm driving myself nuts (and probaby the neighbors). Is it ok to enclose the heat pump in some kind of small shed type structure? The back of the unit is approx. 1.5' from the wooden yard fence so I'm thinking of building a 3-sided structure and leaving that 1.5' space for air flow. Any recommendations for the clearance on the top?
    Default Re: Enclosing Heat Pump?
    I would not do that without consulting the mfg. You need huge quantities of air to absorb heat from. If you restrict the airflow you will significantly raise your operating costs not to mention possibly damaging the unit.
    Ft Lauderdale, Fl
    Quote Originally Posted by psciotti View Post
    You will want to make sure you consult with the manufacturer's instruction manual. Aqua Cal recommends about 2' around the evaporator coil free from walls or shrubbery that can block air flow. This is important as any blockage will reduce efficiency and may cause the unit to fail.
    Also, the space above is important that you do not block or divert flow back down that may recycle to the evaporator coil. This will be colder air, so cycling cold air down will again reduce efficiency and may cause it to freeze up.
    Which "Aqua" heat pump do you have as there are several companies with Aqua in the name? Most scroll compressor heat pumps are about as loud as an air conditioner outside unit. Reciprocol compressors are like a piston engine. Much louder and less efficient.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
  1. heat pump fan
    By JimTom in forum --cleanup--
    Last Post: 06-19-2013, 09:00 PM
  2. enclosing pool help
    By trey3 in forum In-Ground Pool Construction and Repair
    Last Post: 10-17-2011, 06:50 PM
  3. Question about heat pump pool heater and fireman's switch on pump timer
    By HuntnHog in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2011, 08:37 PM
  4. Heat Pump
    By mohawk in forum Pool Equipment & Operations
    Last Post: 09-04-2006, 12:08 AM
  5. Question on enclosing an inground pool...Anyone know about this??
    By Enigma869 in forum In-Ground Pool Construction and Repair
    Last Post: 07-08-2006, 01:58 PM
