Thread: Cost of raising FC by 1 ppm
    Lehigh Valley, PA
    Default Cost of raising FC by 1 ppm
    I got interested in the economy of the different bleach solutions available and thought I'd share my findings with you.
    Cost of bottled bleach:
    Pool store carboy @ 12.5% = $0.0218/oz
    Sam's Club, Clorox Ultra @ 6% = $0.023/oz
    Sam's Club, Clorox regular @ 5.25% = $0.019/oz
    Original Bleach Calculator Formula:
    (1,000,000/PV) * C * UB = FC ppm Added
    Formula reworked for Units of Bleach needed to increase FC by 1 ppm:
    FC * 1/C * PV/1E6 = UB
    My pool volume is 12,000 gallons. Hence:
    1 * 1/0.1 * 0.012 = 0.12 gal = 15 oz @ 10% Pool store ----> $0.33
    1 * 1/0.0525 * 0.012 = 0.23 gal = 29 oz @ 5.25% Regular ---->$0.55
    1 * 1/0.06 * 0.012 = 0.2 gal = 25 oz @ 6% Ultra ----> $0.58
    The pool store chlorine is said to be at 12.5%. I'm using a 10% functional concentration in my calculation because chlorine degrades with time and storage conditions. I have not tested the concentration to get a real number because the dilution factor using my Taylor reagents makes my head explode.
    I use a 4 cup plastic measuring cup to add bleach. You may already know this but Google has a neat units converter. You input "0.12 gal = ? oz" and it returns 15 oz. Or you say "15 oz = ? cups" and it tells you 1.875 cups.
    I should be cleaning house in preparation for weekend guests but this was more fun. Unless I got the math wrong, in which case I'll be really, really embarrassed.
    Default Re: Cost of raising FC by 1 ppm
    Well your math may be correct, but I think you can find much cheaper bleach. I routinely buy 5.25% bleach at the supermarket for $1.49/gallon which comes out to $0.01164 per ounce. I stock up when it goes on sale several times a year for $1 a bottle which is only $0.0078 per ounce!
    Lehigh Valley, PA
    That's a good deal, just about the same as the pool store chlorine. When you buy it at the regular price it comes out to $0.34 per 1 ppm FC.
    heymom1 is offline ** No working email address ** heymom1 0
    Quote Originally Posted by cleancloths View Post
    Do you have a basement? Where do you store this bleach when you buy it ahead? Wish I could, but there's no place to put a large quantity.
    6% bleach here runs about the same price. I just can't store very much at a time.
    So why are we all buying bleach when the pool store chlorine is cheaper?
    Mandeville, LA, USA.
    Quote Originally Posted by Jeffski View Post
    1. It's not available in all locales.
    2. Many people don't have a pool store located conveniently close while almost everyone has easy access to a grocery store and visits one at least weekly.
    3. Relatedly, you don't have to make another trip to another store to get bleach; you can just pick it up while you're at the grocery or Wal-Mart or wherever.
    3. The 12.5% stuff, because most people won't use a whole container at once, whether it's stored in carboys or jugs, requires more handling with a greater potential for spills and splashes that will damage clothing and other things.
    4. The stronger stuff degrades more quickly.
    Store it in the garage or the basement of my store. I don't like stuff over 10% as it degrades very quickly. Further, they require that you give them a deposit on the containers and it is just a pain. When bleach is on sale at the market it is the cheapest form to buy.
  1. Raising pH level wihout raising Alkalinity
    By JMannWV in forum Dealing with Alkalinity and Calcium
    Last Post: 07-31-2012, 11:28 PM
  2. raising alk
    By CanuckPool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 10-10-2006, 08:56 PM
  3. Raising PH
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-08-2006, 11:50 AM
  4. In Ground Pool Cost - Which Cost the Most?
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 08-04-2006, 04:31 PM
  5. Help with raising ph
    By ccc in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-15-2006, 04:42 PM
