My bet is a suction side leak or clog. Filter basket lid on tight? Clogged pump basket or skimmer basket?
You are correct. I checked all my plugs and blew out the line in case of debris. Then I noticed a small leak around the large round seal at the top of the filter. I didn't see at first because when I backwash it drains around the side of the filter. I have never gone into the filter. Do I just take the top off and replace the seal? Do I have to buy the seal at a pool store? Do I have to drain the filter first? Sorry for all the questions!! I don't know anything about this but can follow directions well!!![]()
Janis
It could well be worth your time to pop open Mr Tagalus and see what the sand is like.
I was thinking about doing that in the morning.....So is it as easy as that, just pop open??? I saw a bit of sand in the area where I think the leak is so I know it is getting out some way.
Waste, I believe you helped me last summer with balancing my water and it has been perfect ever since......Thanks
Janis
I took the top off the sand filter this morning and the sand looks good. It is fluffy with a bit of small debris in it, and it doesn't smell bad (my biggest fear!)
Is there anything special I have to do when I reseal the top back on?
I couldn't see any sign of a leak, or weakened spot, so I am going to try to seal it back up and see what happens.
When I turn the filter on, both returns bubble (with air) and then stop. When I backwash it dribbles out but the water looks clean, as did the water in the tank.
Any other ideas on what to check? My pump motor is only a year old and is working fine.
Yesterday it was cloudy so my water looked OK but this morning it is starting to look green. Oh, the pain......hauling all those bottles of bleach.....but much less pain to the wallet.
Janis
I greased and resealed the filter and the pump strainer and still nothing.I guess I am going to have to call someone because I can't see any obvious leaks, and I need to get this back up running asap.
Janis
