I just installed a skimmer sock on both skimmers.
They're designed to catch the "finer" debris and keep it from going to the pump/filter.
Anyone have any experience with these they'd like to share?
40'x28' I/G L-shaped, vinyl liner pool, with an estimated 40,000 gallons of water.
Been using BBB for over a year! Excellent results!
They work great. You'll be surprised how awful the skimmer socks look when you pull them out to clean. YUCK.
CaryB
They're great!
On my system, when the pump isn't running, the bottom of the sock floats up and some of the debris it had caught, dislodges. I now put a small rock inside the sock so it stays down in the skimmer basket when the pump is off.
I've been using them for 3 years. They work great and reduce the number of times you backwash. I replace the sock about once a month--cheap enough!
We use them too and love the "polishing" it does by getting the finer crap out of the water. FYI - you need to check them often to be sure they don't clog up - not much gets through those buggers and they can quickly clog up enough to change pump pressure if there is pollen or other junk floating around.
Once a MONTH? I change mine daily. Of course, I get a lot of dog hair in the pool but even without the dogs, like a few days ago, I had something like a gazillion flying ants in there. Must have been a hatch. And during pollen season it got disgustingly full of yellow pasty gunk.
Changing the sock is part of my daily routine. I rinse it off with the hose, hang it over a fence post, and put another one in the basket. Once amonth? Man, you have CLEAN water!
Excellent ideas!
Thanks!!
It definitely cleans, but the pool was getting too high maintenance and as a busy mom I can't check this daily. I have a micron cartridge filter and my water was pretty clean without this, so I removed mine.
Salinda
Sandy
