Quote Originally Posted by psciotti View Post
SLS - If you set it to run the length of your 40' pool and it ends up going side to side, or a shorter distance before it hits a wall, doesn't it spend an extended time idle waiting for the cycle to change?
Yes... you absolutely want to allow enough time for length to length travel. The "idle time" is no big deal, it's still filtering and polishing the water even if it's not picking up debris.
maybe I'm to anal about this thing - I did read some post that said if you watch these auto cleaners you'll go nuts!!
Grab a cold one and relax.
