Results 1 to 10 of 11
Thread: How / Where Do I buy Liquid Chlorine?
    Default Re: How / Where Do I buy Liquid Chlorine?
    There are many different SWG out there at a wide range of prices. Do a search on this site and you will come up with a lot of different posts on what others have, how much they paid, etc. You can get systems for IG pools starting around $470ish - all the way up to several thousands of dollars. These include on the low end of the price scale the IG Chlorease CLO3, going up to the Aquatrols, Pentairs, Zodiaks, and the Pool Pilots with all the bells and whistles. Many brands and many different types out there with lots of satisfied customers.
    Middle Missouri
    Thanks to all who responded to my post. There's some very good leads here and I know I'll be able to get what I need because of you.
    Beast regards - Jim
    Jim
    16' x 32' / 15,400 gal / IG vinyl
    All testing done with
    PS234 test kit
    Upstate, NY (Dutchess County)
    Default This is my last year with Bleach...
    I'm quickly coming to the conclusion that when all costs are factored in that salt water chlorine generators are more economical. Especially when gas is over $3/gallon.
    Not counting startup and closing... I figure I go through about 100 jugs of 96oz 6% bleach or about $130/year + transportation. If a chlorine generator cell lasts 4 years I think I'm just about even. Anything beyond that I save $$$.
    Plus I'm too lazy even to open a jug of bleach and pour it into the skimmer once per day or two.
    26,000 Vynil Liner L Inground
    Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
    Poolvergnuegen thepoolcleaner Pressure Side Cleaner
    Loop-Loc Mesh cover
    Middle Missouri
    Good perspective. My cost from Sam's works out to be about $2.62 / jug, so if I use 100 jugs the chlorinator solution looks better and better. -Jim
    Jim
    PS234 test kit
  1. Liquid Chlorine?
    By proximo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-01-2013, 11:48 AM
  2. Adding liquid chlorine
    By fschakel in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-06-2011, 08:00 AM
  3. liquid chlorine
    By mrs.rainbow in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2011, 10:24 AM
  4. powdered chlorine vs liquid
    By Bluesky in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-11-2010, 09:27 PM
  5. Liquid shock, bleach, liquid chlorine?
    By rollinrock in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2007, 01:26 PM
