Results 1 to 8 of 8
Thread: Please define "cloudy water"
    Lehigh Valley, PA
    Default Re: Please define "cloudy water"
    Quote Originally Posted by fcfrey View Post
    If you are using Calcium Hypochlorite (HTH, etc) You will see the calcium which has precipitated out of the CalHypo.
    I'm not using Cal-Hypo. I notice this 'dust' when brushing mostly if we haven't been in the pool for a day.
    The bottom and sides of the pool feels clean. I mean, when I slide my feet and hands over it it's, like, squeaky clean, not slick or grainy or anything like that. I've concluded it's dead algae bodies which hadn't been circulated enough to be filtered out. Certainly the water has that crisp sparkle which tphaggerty defined.
    Quote Originally Posted by AnnaK View Post
    If it's "squeaky clean", and your chlorine has been maintained at proper levels, then it's probably just dirt, pollen, etc that has blown into the pool, or dirt that has been tracked in by swimmers. Brush it up and your filter should take care of it.
    Dec 2005
    Pittsburgh, PA, USA.
    Cloudy water is like the CYA test kit. You look in and you cant see the bottom.
    The first thing to dissapear is the drain at the bottom of the deep end.
    Then the whole deep end and you can only make out the liner in the shallow.
    Then if it gets really bad, you start counting how many steps you can see.
    On the path to recovery from "cloudy water" you get excited as new bottom features emerge.
    You have pollen or chemical debris - you will know cloudy water when it hits - and you will read this website like never before.
    Lehigh Valley, PA
    Quote Originally Posted by chemicalbalance View Post
    That's not possible. I read this forum with my first cup of coffee in the morning and my last sip of Tequila at night But I betcha that if I do get cloudy water, I'll post here like never before.
  1. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 11:17 AM
  2. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  3. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  4. Define "aeration" please
    By Gracy101 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-06-2006, 10:33 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
