Thread: changing filter sand
    Default changing filter sand
    Yesterday I changed the sand in my filter, everything seemed to go back just the way I removed it. My problem now is I have air in my lines constantly and no visible leaks anywhere. Is this common or did I do something wrong? Any help would be appreciated.
    Honesdale PA
    Default Re: changing filter sand
    Since you started with a full tank of air it may take time to bleed out. From what I've read on the forum some filters have an air bleed valve at the top, others, like my Hayward, seem to have an internal mechanism for bleeding air. If the bubbles don't go away then the air has to be getting sucked in on the suction side of the pump somewhere. Changing the sand, no matter how you screw up, should cause an ongoing bubble problem.
    Let us know if the situation has improved.
    Unhappy Re: changing filter sand
    I have the same symptoms after changing my sand on Saturday. I went back and read the book on the filter and it said to fill the tank halfway with water before adding the sand. I just loaded up the sand and I think having the water in the tank would have helped to eliminate the air in the sand.........
    Ken J
    Glenside, PA
    16x32 Inground, 20,000 Gals, Pentair WhisperFlo Pump WFDS-24, Hayward Sand FilterS310T2 (with occasional DE added)
    Cool Re: changing filter sand
    Ken, welcome to the forum!! Having the water in the tank also helps reduce the strain on the laterals in the bottom from the sand being dumped in.
    try un screwing the pressure guage from the filter to let some of the air bleed out.
    May 2011
    After draining the water out, you should be in "backwash" mode when you turn on your pump. This will make the filter tank fill with water from the bottom up making life easier on the laterals at the bottom and less likely to cause a crack/break on one of the laterals. If you have an air bleeder, keep that open until water starts coming out of it, and then close it. Then you should be good to turn the pump off and switch back over to "Filter" and turn the pump back on.
  1. Changing Sand
    By Cindy32tn in forum Dealing with Algae & Slime
    Last Post: 06-27-2012, 09:14 PM
  2. Changing filter sand
    By tado921 in forum Pool Equipment & Operations
    Last Post: 06-03-2008, 11:10 PM
  3. Changing Sand in Filter and Random Filter Question
    By newbie2pools in forum Above-Ground Pool Construction & Repair
    Last Post: 07-24-2006, 03:38 PM
  4. Plumbing Questions - changing from sand to de filter
    By let_her_flicker in forum Pool Equipment & Operations
    Last Post: 07-05-2006, 01:33 PM
  5. help needed with changing sand in filter
    By chemstick in forum Pool Equipment & Operations
    Last Post: 06-14-2006, 08:04 AM
