Thread: Is this correct? 8 oz trichlor tab adds 5.6ppm in 10k water?
    Amir is offline Registered+ Thread Analyst Amir 0
    Potomac, MD, USA.
    Default Is this correct? 8 oz trichlor tab adds 5.6ppm in 10k water?
    Amir
    Potomac, MD, USA.
    Default Re: Is this correct? 8 oz trichlor tab adds 5.6ppm in 10k water?
    I found my answer here. Thanks
    http://www.csgnetwork.com/poolchemcalc.html
    the bleach used in the calculator is 12%
    I get 5.48 ppm (that is, about 5.5 ppm) in my spreadsheet, but 5.6 ppm is close enough.
    Potomac, MD, USA.
    Thanks Richard,
    Above site is another one that Chlorine calc does not work in my firefox (other calcs work) but works in IE! I should have looked at your spreadsheet first. I did download it - with your permission!
    amir
  1. Should I try to correct pH?
    By jilted in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-29-2012, 05:01 PM
  2. Trichlor & PH
    By Simmons99 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-24-2006, 04:26 PM
  3. Is it possible pool store adds stabilizer to sodium hypochlorite?
    By finch in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-06-2006, 08:49 AM
  4. Who is correct: Water hardness test
    By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-08-2006, 12:21 AM
  5. Is this correct
    By fireray in forum In-Ground Pool Construction and Repair
    Last Post: 04-28-2006, 01:27 PM
