Polly,
Your pH is at the top of normal so you could add acid to get it to 7.4 or so or you could wait and test again in a day or so to see where you are.
You can swim VERY shortly after adding acid....it dilutes almost immediately.
Your Cl will go away in a day if you don't add some CYA....that would be my first priority. download bleachcalc and you can figure how much CYA (I'd try to get to 30ppm for starters) and how much acid you'll need.
Meanwhile......GO swimming!![]()
