Thread: At the pool store today .
    Jul 2006
    Middle of the mitten , Mi
    Default At the pool store today .
    I sprang a leak in my hose from filter to pool so off to the pool store to get another , I took along my sample bottle so they could check my CYA when there as I have used both bottles now from my Talor kit .
    While she was running the test I told her wife had gotten the conditioner at this store and I was trying to get from 20 to 30-35 range .
    She said "Oh you got this contitioner ( 4 lbs ) you just go add all of it as having a high reading is great , you don't lose FC and I use tabs and my reading is 151 , bah bah bah "
    I said "I don't want it to go to high as the FC works better to kill stuff "
    She said repeated to me again that high lvls were good etc . She then told me my aklinity (spelling) was higher than normal , and did I want some chem for it .
    I said " I have a liner in my AG pool not cement and that won't be a problem for me
    She then didn't say squat
    My conditioner lvl was 30 , up from 20 3 days before . I just read that you here that you should wait a week before testing again . Which I will now do . But it seems alreay my FC lvl is staying up better than at 20 which was taking with this heat wave a 3 quarts or Ulta bleach a day . I think I am if not there at least very close atm .
    Now I just wanted to say this :
    THANKS , but for this forum I would be again under the pool store evil ways . Was so nice to be able to shrug off her info to me and just get what I wanted . A nice new hose and a pool toy for my neice
    Pool is so nice and clear and no poly this year and it's so much cheaper .
    Thanks again
    Jul 2006
    Default Re: At the pool store today .
    Hey Sprocket, is Cyanuric Acid (Stabilizer) what you are referring to as Conditioner?... and I think your alkalinity level is important whether or not you have a vinyl or concrete pool, maybe what you are referring to is Calcium, which is needed for a concrete pool but is not as important in a vinyl pool... and based on your Conditioner (stab?) level of 30, an FC level of 20 seems more like a shock level, I think you should be down in the 3-5ppm of FC, maybe someone else can chime in here on those numbers...
    Jul 2006
    My CYA is 30 now up from 20 . <-- at 20 was loseing alot of clorine every day to sun .
    My FC is at 3 to 6 . I usually add anytime it's below 4 .
    PH is 7.2
    I don't really test for anything else , if I test for Alkalinity and try changeing it , it ( if I remember right ) always messes up my PH . So I quit doing it .
    I have a Taylor K-2006 test kit .
  1. Pool Store selling "bleach", or the pool store blinked!
    By Spensar in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-02-2013, 11:01 PM
  2. percentage of hydrochloric acid, hardware store vs. pool store
    By dhanger in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-21-2011, 02:45 PM
  3. Bought a pool today now help!
    By GA Mark in forum Above-Ground Pool Construction & Repair
    Last Post: 08-11-2006, 02:46 PM
  4. pool didn't go up today....
    By Trimom in forum Above-Ground Pool Construction & Repair
    Last Post: 07-26-2006, 03:07 PM
  5. Today is why we have a pool.
    By bparks in forum General Interest
    Last Post: 07-19-2006, 02:08 PM
