Thread: hole in sand filter tank
    Burlington, NC, US.
    Default hole in sand filter tank
    There's a small hole in my sand filter tank and it's spraying water. Looks like a couple of pin holes not a lot of water loss. Can I fix this? Suggestions on how to do this if possible. If not what do you guys recommend I replace it with. Another of the same or is there a better way.
    Thanks in advance for your help.
    Jay in NC
    18 x 36 vinyl 23,000 gal. Located Burlington, NC
    Default Re: hole in sand filter tank
    Pool epoxy, from the inside. It sets up underwater, and the pressure from the inside will help it seal.
    Or get a plastic welder and weld it with multiple layers.
    tenax is offline Registered+ Widget Weaver tenax 0
    jb weld! i used some on the side of the autopilot manifold i burnt through with a soldering iron (long story) and used jb weld..no water leaks, stands up to the pressure, stuck fine to the pvc.
    Burlington, NC, US.
    Thanks guys...I may give JB Weld a try on the outside of the tank. I really don't want to mess with going inside the tank. I'll sand it good and give it a try.
    Thanks for the reply........Jay
    ScottS is offline Registered+ Thread Analyst ScottS 0
    Covington, LA.
    Just out of curiousity... what kind of tank is this?
    I have a small hole (crack) on the inside of my old filter but I may patch it and hold onto the tank.
    Let me know how the repair turns out.
    Thanks.
    Jul 2006
    SE Georgia
    I was up late the other night watching TV.
    Why would anyone use anything else but
    Leak Ender 2000 !!
    <Just kidding folks! Don't waste your money!>
    40'x28' I/G L-shaped, vinyl liner pool, with an estimated 40,000 gallons of water.
    Been using BBB for over a year! Excellent results!
  1. Pump sucking air and filling filter tank
    By MRL325i in forum Pool Equipment & Operations
    Last Post: 06-14-2011, 11:30 PM
  2. DE filter Tank- older model- New to forums- appreciate the help..
    By Bella in forum Pool Equipment & Operations
    Last Post: 06-13-2011, 08:12 AM
  3. Is it possible to purchase the plastic tank of a Hayward Sand Filter?
    By 98gtx in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2011, 03:54 PM
  4. Leaking filter tank - can it be patched?
    By threekittens in forum Above-Ground Pool Construction & Repair
    Last Post: 07-23-2008, 08:10 AM
  5. media level in a sand filter tank
    By ScottS in forum Above-Ground Pool Construction & Repair
    Last Post: 03-25-2007, 01:12 AM
