Thread: Green or mustard? How to tell the difference?
    mbar's Avatar
    Ashland, PA
    Default Re: Green or mustard? How to tell the difference?
    No matter what kind of algae it is, bleach, bleach, bleach. You have to get your pool to shock levels, and keep it there running the filter 24/7. Brush the pool daily. Check chlorine levels 3x a day if possible, most importantly check after the sun goes down - and in early morning to see if you are losing any chlorine overnight - once you hold chlorine over night, keep it at shock for 3 more days, then let the levels fall back to normal. If you don't get it all it will start to grow back - so continue testing once the sun goes down and keep your chlorine at the high end of the best guess chart for a while. If you notice you start to use a lot more chlorine - then start to shock again.
    Northeast PA
    would not necessarily agree with bleach, bleach, bleach to combat mustard algae. That won't work. You need polyquat. Just look for "poly" in the ingredients, preferably 60%. Get it at Walmart. I've been there and done that.
    If you truly have yellow/mustard algae and not pollen or dirt, then it takes a higher level of chlorine to kill it. See this thread for additional info (and this thread for some pictures). The shock level required is an FC level that is approximately 55% of the CYA level if one lowers the pH to 7.2 before adding the large amounts of chlorine needed. The shock method of maintaining a high FC level is the same for this algae, just at a higher FC level (i.e. you must keep adding chlorine to maintain the high FC level and not let it drop). In areas where the yellow/mustard algae is regularly reintroduced (blown in), after the algae is gone, then it may be necessary to maintain the "Max" level of chlorine from Ben's chart or roughly an FC of 15% of the CYA level.
    The results with pool owners using PolyQuat 60 to kill this algae have been mixed though it does seem to help prevent it (as it prevents all algae) IF lower chlorine levels are maintained. That is, chlorine alone can prevent and kill this algae, but higher levels are required as noted above. The use of 50 ppm Borates is another option for prevention.
    Note that yellow/mustard algae is often reintroduced into a pool from bathing suits so be sure and thoroughly wash bathing suits (hot soapy water) after you've been in a pool with such algae.
    As for determining for certain whether it is yellow/mustard algae vs. pollen, have an open bucket of water near the pool and see if it gets yellow dust on its surface. Also, use a skimmer sock and see if it collects a lot of material and see if it is slimy to the touch (algae) or not (pollen). Take a small sample and look under a microscope -- pollen will look like round balls (sometimes a bit rough or spiked) while algae has some transparency to it and is shaped more like cells with some distinguishable contents.
    Richard
  1. Wanted: Mustard algae or suspected mustard algae
    Last Post: 08-30-2007, 09:40 PM
  2. Green algae? Mustard algae?
  3. Difference in DE filters?
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 05-12-2007, 12:35 AM
  4. PS234 & HTH 5-way difference...
    By csevel in forum DPD-FAS based testing
    Last Post: 06-09-2006, 11:08 AM
  5. What's the difference between AG and IG heater???
    By The Mermaid in forum Pool Equipment & Operations
    Last Post: 06-02-2006, 07:25 PM
