Closed Thread
Results 1 to 3 of 3
Thread: Loud Pump Noise?
    Canada.
    Default Loud Pump Noise?
    Hello everyone
    I have 27' AG round pool and it is my 4th summer with it. The water is clear, pump is working, but today when I was finished vacuuming, the pump starting making a loud buzz noise (constant) and continued. I turned it off for a little while, checked the filter, all clear, pressure is reading ok on gage when it is running, but it is really loud now. Is this a sign that the pump is on its way out? God I hope not! It has been running 24/7 for the last week but last year I also ran it pretty well 24/7 and it didn't make any noise.
    I'm assuming since it is running, and pressure is ok, water is circulating it should be ok, but I can't understand why it all of the sudden got so loud.
    I turned it off for now and will leave it shut off for a couple of hours, but I thought I would ask if anyone else had a similar thing happen and if so did you eventually have to get a new pump?
    Any suggestions would be appreciated.
    Mary
    Mary
    27' AG
    Default Re: Loud Pump Noise?
    It could be one of a few of things:
    1. impeller is loose - check for play of impeller
    2. bearing going bad
    3. Something inside pump chamber - check for a pebble or something similar
    Honesdale PA
    There is a duplicate thread located here:
    http://www.poolforum.com/pf2/showthread.php?t=7572'
    so I'm locking this one.
Closed Thread
  1. Pool Pump Makes Strange/Loud Noise
    By PoolKid in forum Pool Equipment & Operations
    Last Post: 06-26-2013, 09:40 AM
  2. Loud Pump
    By vchavez in forum In-Ground Pool Construction and Repair
    Last Post: 06-24-2009, 01:21 PM
  3. Pump making loud buzzing noise
    By Islander2C in forum Pool Equipment & Operations
    Last Post: 06-18-2007, 09:41 AM
  4. HELP -- LOUD Pump
    By wrinkleigh in forum Pool Equipment & Operations
    Last Post: 05-25-2006, 02:46 PM
  5. pump very loud
    By sunofthebeach in forum Pool Equipment & Operations
    Last Post: 05-09-2006, 01:54 PM
