Results 1 to 10 of 11
Thread: Adding baking soda when pH is high??
    Default Re: Adding baking soda when pH is high??
    Quote Originally Posted by boscogabby View Post
    What should you do if your pool has a vinyl liner where it has been said that calcium hardness is not important or needed?
    Ignore it.
    what he said.
  1. pH to high after adding baking soda to raise TA - Help Please
    By myLABSpool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2010, 01:30 PM
  2. How much baking soda can I add in a day?
    By mwsigler in forum Dealing with Alkalinity and Calcium
    Last Post: 06-16-2007, 07:45 AM
  3. is adding baking soda ok if chlorine is high
    By traceyb in forum Above-Ground Pool Construction & Repair
    Last Post: 06-06-2007, 07:16 AM
  4. How much baking soda?
    By thewayne in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2006, 06:34 PM
  5. adding baking soda
    By mikewaterskis in forum Dealing with Alkalinity and Calcium
    Last Post: 05-28-2006, 02:06 PM
