Hello,
I just bought a house that has a gunite pool with a single main drain. The pool is probably 40 years old.
I haven't been able to locate valves that deal with the main drain nor the skimmer.
I noticed that dirt around the main drain doesn't get sucked in and also confirmed that the main drain doesn't seem to be working.
The skimmer works just fine.
A pool cleaning guy suggested that I test it by putting in a tennis ball to cover the skimmer hole to see if the main drain would then start to suck.
My questions:
1. Is that safe to do?
2. Is it normal that old pools don't have any valves to control the water flow?
Thank you.
If you're not sure just see how many lines come up into the pump - if it's only 1 the MD is probably plumbed through the skimmer and you'll need the special attachment to get any water movement through the drain.
