Thread: Air bubbles in return lines, found & fixed problem
    Lehigh Valley, PA
    Default Re: Air bubbles in return lines, found & fixed problem
    Really? Leaks when you shut off the pump? Maybe that is the problem with mine then, after all. I can't see the plug when I shut off the pump, have to crawl back there and flip the toggle. And there is water on the lip right below the plug . . .
    It'd be worth to buy a new plug and put that in than to disassemble all the plumbing and put new Teflon tape and gunk on the threads.
    Thanks for posting your experience!
    anna - if yours is just loose, tighten it, if it still drips, lube the o ring and/or put teflon tape on the threads of the plug - bcb1 only replaced it because it was broken.
    Fittings from one end to another should be checked. We had a hairline crack in male end of the the solar panel diverter valve that caused all our air bubbles. It was not noticable except under close inspection. Just a little movement of the valve while inspecting caused it to almost fall apart - we caught it before that happened by itself, either by water pressure or someone bumping it, etc. What a disaster that would have been.
    As soon as bubbles appear somewhere they don't belong, start checking everything before the minor crack becomes a failure, then a flood.
    Lehigh Valley, PA
    Talking Re: Air bubbles in return lines, found & fixed problem
    Quote Originally Posted by matt4x4 View Post
    Well, lo! I found the leaks. It isn't the plug on the pot and it isn't a crack in the pot like we first thought. There are two leaks on the fittings of the PVC pipes, the one going into the pump and the one going out. The way the water runs from one of the leaks, it collected on the lip of the pot which is what made us think the pot itself was the problem.
    The real problem is that we're both as old as dirt and getting way down there to look at the fitting was more than our knees could take, so we didn't actually get all that close and personal to the plumbing. But they bothered me. It's like Mom said, when bubbles appear, something is wrong, and so I did crawl around there this morning. The dogs thought that was all pretty weird
    My husband can go wrap the Teflon and tighten the connections. More than likely he'll make a weekend project out of it with a long trip to the hardware store for yet more tools and jigs and pieces. Oh well. Fun is where we find it.
  1. Found the reason for so many air bubbles.
    By St8kout in forum Pool Equipment & Operations
    Last Post: 08-20-2012, 03:59 AM
  2. Bubbles in return lines
    By Phillbo in forum In-Ground Pool Construction and Repair
    Last Post: 05-10-2012, 08:56 PM
  3. Air Bubbles in Return Lines
    By dnspade in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2011, 02:05 PM
  4. DE Filter Problem - Fixed
    By wa2asb in forum In-Ground Pool Construction and Repair
    Last Post: 06-24-2010, 05:37 PM
  5. Air in Return lines
    By berardi17 in forum In-Ground Pool Construction and Repair
    Last Post: 07-02-2006, 04:51 PM
