Hi to all,
Does anyone here prefer dry acid to the liquid acid? How are you all adding the acid to your pool?
I like the dry better because it doesn't let off the fumes - but have noticed that you have to dissolve and add slowly with the filter on high or it etches the bottom if it gets to sit - hope that isn't a bad thing - the bottom is just rough in one area and I am not doing that anymore.
Have a new IG plaster pool with salt system.
THANKS!
