Results 1 to 9 of 9
Thread: Leak in skimmer piping
    waldreps is offline Registered+ Thread Analyst waldreps 0
    Lake Park, MN, USA.
    Default Re: Leak in skimmer piping
    So how do you know if pvc fittings are schedule 40 or not? I look at the store and don't see any markings on them. Do I have to get them from a pool store or does Home Depot or someone have them?
    Stacy
    Honesdale PA
    You're right and someone please correct me if I'm wrong as I'm not a plumber. Just looked at some generic Home Depot ones in my basement and no markings. I believe sched-40 refers to the pressure rating which is determined by the thickness of the pipe or valve body and the depth the mating pipe seats for a good pressure joint. Sched-40 pipes seat about 1.25". The ball valves have about the same seating depth. I've also always seen only one variety at a HD or Lowes. There are better, more expensive valves available but I've never used them.
    Hope this helps.
    Lake Park, MN, USA.
    Boy, concrete is tough...lol! I rented a saw to cut it and it worked great. It cut through it like butter. I cut the whole area into four smaller pieces and thought I would be able to use a pry bar and get the pieces out of there. No dice! Just bought a big sledge hammer and will start pounding away as soon as I find the time. I was hoping to avoid having to do that. Oh, well. I'll get some much needed exercise!
    Stacy
  1. How to repair an IG liner leak at the skimmer interface and replace skimmer
    By ralph in forum In-Ground Pool Construction and Repair
    Last Post: 02-29-2012, 10:37 AM
  2. Help with Skimmer leak.
    By pratzert in forum Above-Ground Pool Construction & Repair
    Last Post: 07-14-2011, 10:02 AM
  3. Skimmer leak
    By dtcdmy4sons in forum In-Ground Pool Construction and Repair
    Last Post: 06-16-2011, 12:13 AM
  4. Skimmer Air Leak
    By stin0000 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-30-2009, 08:17 AM
  5. skimmer leak
    By gonefishin in forum Above-Ground Pool Construction & Repair
    Last Post: 05-27-2006, 03:35 AM
