Results 1 to 9 of 9
Thread: Leak in skimmer piping
Threaded View
  1. #2
    simsjim is offline Registered+ Thread Analyst simsjim 0
    Jul 2006
    Default Re: Leak in skimmer piping
    A few things I've learned by doing my own that may be helpful to note -
    Use Schedule 40 PVC. If you can, go with 2" diameter all around. That will give you more flexibility when it comes to pump HP, etc
    Try to get the deepest unions you can find, the pipe should go into the union at least an inch because of the high GPM flow rates.
    Measure Twice (maybe even three or four times) and cut once. Don’t forget to add the inches that are inside the unions when measuring pipe distances.
    Mock-up a dry-run with all your plumbing. That is - do a detailed layout first, both on paper and with the physical plumbing. Lay it all out on the ground so you know what is going where.
    If you wanted more/new control valves…now is the time to do it. The Jandy website has a decent valve schematic page that shows the best layout for various pool equipment combinataions.
    Buy extra pvc cleaner, cement, sand paper, a few extra unions and extra pipe. There is nothing more annoying than having to run back to the big-box while in the middle of the job. You can ALWAYS return what you haven’t cut, opened or used.
    Don’t forget the thread seal for the pump's threaded joins - (make sure its JUST sealant and not Lock/Seal) It looks like toothpaste. Some folks like Teflon, but I've never been a big fan - its neater yes, but under pressure it gives out over time (IMHO).
    Using two 45 degree elbows at turns produces less friction (less head) than using 90s
    I used threaded union connections just before the pump for easy pump removal. If you have to bring your pump someplace for repair later on down the road, no cutting.
    There are different grades of PVC glue - make sure you get all-weather, heavy bodied, low set, high strength PVC solvent cement used to join PVC pipe and fittings. Make sure it's for all classes and schedules of pipe and fittings, exceeding the diameter of your plumbing. A personal preference is clear, as the blue can be unsightly on those above-ground joins.
    Invest the 30 bux in a decent PVC cutter that can handle 2" diameter. WELL worth it.
    Try not to 'end' at a complicated join, so if you chump something, you don’t have to cut away a lot of work to fix the mistake.
    Work fast with the PVC cement - the set up time is minutes. Paint both sides of the join, stick it in, turn a quarter turn - in ONE direction, and hold. Hold those joins together with both hands for at least a minute. PVC cement tends to force the pipes to 'drift' out of the join, so hold it steady.
    Off course, don’t smoke around PVC cement, and don’t inhale too much vapor either.
    Enjoy,
    J
  1. How to repair an IG liner leak at the skimmer interface and replace skimmer
    By ralph in forum In-Ground Pool Construction and Repair
    Last Post: 02-29-2012, 10:37 AM
  2. Help with Skimmer leak.
    By pratzert in forum Above-Ground Pool Construction & Repair
    Last Post: 07-14-2011, 10:02 AM
  3. Skimmer leak
    By dtcdmy4sons in forum In-Ground Pool Construction and Repair
    Last Post: 06-16-2011, 12:13 AM
  4. Skimmer Air Leak
    By stin0000 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-30-2009, 08:17 AM
  5. skimmer leak
    By gonefishin in forum Above-Ground Pool Construction & Repair
    Last Post: 05-27-2006, 03:35 AM
