Usually a dull looking, metallic tasting water is associated with high TDS. This is not always salt, however, bleach will add salt to your pool. With high TDS, your chlorine will be less effective. If this is salt, it will not affect your chlorine effectiveness.
According to EPA, 200 ppm of salt is the point at which salt can be detected in drinking water (at least that's what the EPA maximum salinity standard is for drinking water)
Leslie's should be able to do a TDS test and a Salinity test.
You should take a sample of your fill water and have them test that to see what your TDS of the tap water is. Rule of thumb is that if you do not have a salt pool and your TDS is more than 1000 ppm higher than your source water, you should drain some down and dilute it.
