Results 1 to 4 of 4
Thread: PH too high?
    Canada.
    Default PH too high?
    Hello everyone.
    Well for this year I used bleach only and I was so nervous, but it worked out beautifully and so much cheaper.
    Only had to add 7 (3.6L of liquid bleach at 5.25%) containers and 2 boxes of 500g baking soda and my water is perfectly balanced!
    Only one little problem maybe. my pH is reading 8.0 which came down from 9, but the pool store told me that was too high and I knew that. They suggested I use 500g of Easy Down.
    Does that sound right with all of you?
    Would that reading of 8 keep my pool water from being "crystal clear" because I have been vacuuming every day and levels are all ok, but my water is not as "clear" as I would like it.
    Any suggestions would be much appreciated!
    We finally have a warm day and my son is so anxious to get in that pool.(27 AG - no heater) even with the water only around 70! yikes!
    If I add something to lower pH can people still swim in water today?
    Mary
    27' AG
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    Default Re: PH too high?
    You can use muriatic acid to lower your ph, and can swim right after - it is diluted in your pool water . Be careful with it -open it downwind, and pour into the return water flow. You didn't post your other numbers. Sometimes high ph along with high alkalinity can cause your water to not look "crystal clear" but there are a lot of reasons that water can be a little cloudy
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
    Canada.
    Here are my other numbers
    pH 8.0
    Total Alkalinity 110
    Calcium Hardness 120
    Free Chlorine 2.0
    Total Chlorine 2.0
    Combined chlorineC 0.0
    Stablizer 50
    Mary
    27' AG
    Bring the ph down a bit with muriatic acid as Marie advised. Also, with cya of 50, you need to keep your chlorine between 3-6 all the time. 2.0 is too low and is an invitation to algae. Your alk and calcium hardness numbers are fine.
  1. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 04:47 PM
  2. High amounts of DPD Powder needed!! To high or no Clorine?
    By KaseyNewman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-16-2012, 10:52 PM
  3. High Phosphates > 1,000 & High Nitrates 90ppm
    By applepar in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2011, 04:49 PM
  4. had algae, PH high, TA high, water now cloudy
    By Mom4fun in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-12-2011, 12:09 PM
