With a given pipe size you don't hit a brick wall at some flow rate. All it means is that to ram more water through a given pipe size you just need more pressure. Consider a fire hose nozzle where you want to throw a stream a great distance. More pressure. You don't want this in a pool circulation system. You want the lowest pressure and most flow therefore the largest pipe that is reasonable. Hope this clarifies things a little.
