Results 1 to 10 of 11
Thread: Taylor Complete FAS-DPD Kit
    Jul 2006
    Default Taylor Complete FAS-DPD Kit
    Ok... getting confused...
    Looks like I have a DPD kit, not a FAS-DPD.
    Can I replace the reagents I have with different ones and use the same little tubey thing? Or would I be better off just to go ahead and buy a new kit?
    I have a local Leslie's, but they have been real butt-heads lately. Not very nice. Where can I order a good kit?
    Are these good choices?
    Taylor Chlorine FAS-DPD Service Test Kit from Leslies (Still Leslies, but not the local people which is ok for me)
    http://www.lesliespool.com/shopping/...roductID=13142
    Taylor Complete FAS-DPD Kit From In the Swim
    http://intheswim.com/Pool-Chemicals/...e-FAS-DPD-Kit/
    Is this what I should be looking for? I don't mind spending less if there are other sources/kits I could be looking at.
    Ed
    Thanks,
    Ed
    33,000 Gallon
    20'x40'
    Vinyl
    IG
    Front Royal, VA
    Default Re: Taylor Complete FAS-DPD Kit
    I bought mine directly from Taylor Technologies. I have the K-2005 and I only paid 56.50 for it and rec'd it in 2 days. The pool store was selling it for 82.10, same thing. There's a K-2006 that's a little more, but I don't recall the difference.
    The K-2005 is the DPD test. The K-2006 is the FAS-DPD test.
    You can do a cheaper upgrade by just buying the FAS-DPD test kit--that's all it does. I think it's now gone up to $25.
    Leslie's used to sell it too, for about $20 but seems to have stopped.
    But that single test will give you the equivalent of the K2006 a lot cheaper, since you have the K2005.
    joelq is offline Registered+ Thread Analyst joelq 0
    Frisco, TX
    I'd like to "upgrade" my K2005 with just the FAS-DPD test kit but can't seem to find a supplier online. Does anyone know what the model number is, or a supplier that carries the kit? I still have a pretty good supply of the rest of the reagents for my K2005 so don't really want to buy another "complete" kit just to get the FAS-DPD kit.
    Go to Taylortechnologies.com and here's the link:
    http://www.taylortechnologies.com/pr...D=1&KitID=2185
    It's kit # K-1515-A and it's less than $24.
    Or you can go to Leslies On-line and buy the three reagents you'll need:
    1. FAS-DPD powder (called DPD powder but it's the right stuff)
    2. FAS-DPD Titrating Agent
    and
    3. DPD Reagent #3 (this is the CC test)
    4. You'll also need a test container with a 10 ml line on it. You should already have something that will do the job in your kit.
    Then you'll have the FAS-DPD test--for about $20.
    OK: That's 2 alternatives I've given. Should be enough
    Jul 2006
    Ok, so the K-1515-A will test FC and CC?
    Is there a titrating test for pH or are all the pH tests color matching?
    ...And my current DPD kit will give me all the other tests I need right? i.e. CYA, TA, CH...
    Ed
    and
    Thanks,
    Ed
    33,000 Gallon
    20'x40'
    Vinyl
    IG
    Quote Originally Posted by CelticDaddio View Post
    Ed
    I've never seen or heard of a titrating pH test.
    This test, the 1515-A is the FAS-DPD FC / CC test included in other kits.
    The other tests should be fine.
    Upstate, NY (Dutchess County)
    Default Lamotte ColorQ
    Once my PS234 reagents run out I think I'll buy a Lamotte ColorQ (if the reviews are good).
    http://www.lamotte.com/pages/pool/newprod.html
    http://www.lamotte.com/pages/common/...truct/2056.pdf
    http://www.askalanaquestion.com/elec...ters_store.htm
    It's Expensive (~$145 delivered) but it has enough material for 140 FC, TC, PH, ALK, CH tests and 50 CYA tests which should be good for 3 seasons.
    26,000 Vynil Liner L Inground
    Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
    Poolvergnuegen thepoolcleaner Pressure Side Cleaner
    Loop-Loc Mesh cover
    Honesdale PA
    Check here for the K-2006 at $49
    http://www.spspools-spas.com/
    Go to SUPPLIES then KITS and look toward the end of the multi-page listings.
  1. taylor- 2005 vs taylor-2006
    By axell in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 02-11-2012, 11:05 PM
  2. just did complete test heres #s
    By airraid1999 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2011, 01:44 AM
  3. Another complete renovation--Ideas please !!
    By cableguy1 in forum In-Ground Pool Construction and Repair
    Last Post: 05-06-2008, 10:16 PM
  4. New Pool Complete
    By tylermcc in forum In-Ground Pool Construction and Repair
    Last Post: 05-01-2008, 09:34 AM
  5. Baquacil Conversion Complete
    By duckmka in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-11-2007, 12:57 AM
