Results 1 to 10 of 12
Thread: Had pea soup but now....
    Default Re: Had pea soup but now....
    First of all, welcome to the forum!!
    We need chem #s (pH, alk, CH ...) to better tell whethewr it's calcium or not. Please post the full test #s and I or someoneelse will tell you what's going on.
    ps. Don't use a brillo pad on the liner!
    lukw646 Guest
    I will get some #s in the a.m. I used a non-scratch brillo (the kind that you can use on cars that don't hurt the finish) It came off with just some moderate scrubbing. I picked up a pool scrubber today but won't try it until Sat. p.m. Thanks, again.
    By the way, leaving a pool uncovered over the winter doesn't necessarily mean pea soup in the spring. I didn't cover mine, but the water stayed clear. A little dirt on the bottom, but that is all. Al (Poconos) never covers his either. So, it is possible to leave it uncovered and be OK come springtime.
    And..... welcome to the forum!
    lukw646 Guest
    Good morning,
    Here's what I got this a.m.
    FC - 0
    CC - 0 (added 1/3 gal bleach)
    TA - 250
    PH - 7.6
    CYA - filled the reading tube to the top but still could see the dot that is suppose to disappear
    Hardness - couldn't get a reading after 20 drops so it must be way over 500.
    Stuff on the sides that I scrubbed off has not shown any signs of trying to come back.
    Water is still cloudy but it looks to be getting better.
    With the readings I got wouldn't it be better to finish scrubbing the (whatever it is) off and drain and refill?
    Thanks, again
    Smile Re: Had pea soup but now....
    Your idea of getting the stuff off and draining/ refilling sounds very workable. I'd take a test of the fill water for pH alk and hardness - sounds like the problem may be being exaserbated by the fill water, so if it is the fill water draining and refilling may not do any good If you don't mind the cleaning/ draining/ refilling and the fill water is good, it will probably save you a lot of time getting the water ballanced. If the fill water is ~ the same chem make-up as what's in the pool, you're going to want to drop the alk and run with a lower pH - it'll probably take quite a while to get the alk down and use a bunch of acid. Please let us know and we'll help you.
    Oh yeah, be very!! careful!! draining a liner pool!!!! you should leave ~ 6" of water in it. If you don't know why I'm saying this, please ask for further info!
    Best of luck with this!
    lukw646 Guest
    Well, I didn't test the water today. I drained it down to about 24" and scrubed and scrubbed. It came off and then I vac'd with it on "waste" and dropped it to ~ 18". Looks a lot better and am refilling now. I just for the heck of it tested the hose water and the FC was 5 and the PH was 7.8. So we will see what it is in the a.m. BTY I'm using a Walmart AquaChem 6 ways, it that good enough or should I go to a Taylors or something else?
    Have a good night.
    Thumbs up Re: Had pea soup but now....
    Sounds like things are comming along nicely You've got to know the pH, alk and hardness to be able to tell if calcium scale will form, if your kit is not strips and the reagents are fresh/ good, the Walmart kit is fine. Depending on the #s, you may be able to keep the calcium in suspension by running the pool at a pH of 7.2 - 7.4, or you may have to airate off some of the alk. Thanks for keeping us posted, the more we know about your pool, the more we can help.
  1. Pea Soup Pool
    By Anonymous [GDPR] European in the UK in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-25-2012, 01:43 PM
  2. Pea Soup
    By lisak in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-15-2009, 09:38 PM
  3. No Pea Soup
    By CanuckPool in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-25-2007, 02:33 PM
  4. Pea Soup, Polyquat & Antifreeze
    By CoffeeBean in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-04-2006, 08:59 PM
  5. Can you clear pea green soup?
    By Rangeball in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-26-2006, 10:27 AM
