Thread: Testing for high CL levels with drop kit
    Jul 2006
    Default Testing for high CL levels with drop kit
    My test kit, as most do I suppose, only reads to 5 ppm Cl. When I am trying to kill algae, how do I test for Cl levels at shock level, i.e. 15 - 20 ppm for my stabilizer level?
    Thanks,
    Ed
    Thanks,
    Ed
    33,000 Gallon
    20'x40'
    Vinyl
    IG
    Front Royal, VA
    Default Re: Testing for high CL levels with drop kit
    Dilution..
    Carl recommends a shot glass with 1 part pool water and 3 or 4 parts distilled water.
    However many parts you have is what you multiply the reading by to get your actual level.
    For example:
    1 part pool water + 3 parts distilled water = 4 parts water
    Multiply your reading by 4 and that will give you a good sample of the pool.
    You must use distilled water--steam-distilled water is available at most supermarkets and discount drug stores--a gallon is cheaper than a gallon of bleach!
  1. Testing for high chlorine levels
    By George in GA in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2012, 03:17 PM
  2. Testing Ph with high Cl' levels?
    By lstinthot in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-24-2012, 03:29 AM
  3. Testing high chlorine levels (without a good testkit)
    By Watermom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-03-2010, 01:52 PM
  4. Testing High Chlorine Levels
    By thelma in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-14-2006, 08:07 PM
  5. Testing high chlorine levels
    By psciotti in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-28-2006, 02:28 PM
