Well, the liner isn't loose, it's pulled tight, like the liner shrunk and is pulling away from the corners. So, I can't even push it back to the corner.
In past years I've had the liner fall off on the sides and I've been able to use a hair dryer to stretch it and lock it back in with liner lock. But, in the corners I can't do that because the liner is stretched so tight.
