Results 1 to 10 of 19
Thread: Pucks
    jrv331 is offline Registered+ Thread Analyst jrv331 0
    Default Pucks
    What is the name of the chlorine tablets/pucks that will not raise cya? I see so many terms I think Im getting mixed up.
    John
    Michigan
    Default Re: Pucks
    I don't remember seeing anyone say that there was such a thing. Why aren't you considering simply using bleach?
    Why BBB? Because money can't buy happiness, but saving it sure can!
    Default Re: Pucks
    There is a cal hypo product in a different form that does not have cya but its not used the same way as the trichlor pucks and you CANNOT mix trichlor with cal hypo - yikes.
    If I am going on vacation for a longer time without someone to babysit the pool, I will clean well, superchlorinate/shock, cover and set my pump timer to run longer than usual. I have never had issues.
    Default Re: Pucks
    I use bleach while at home, but Im going on vacation and have no one that can care for the pool. I want to put some tablets in my chlorinator so I can atleast have some chlorine level while away.I will leave th pump on low 24/7 while gone. My current cya is 70 and I dont want to raise it. I thought there was a form of non stablized chlorine that came in tablet form.
    John
    Default Re: Pucks
    Yep, nothing out there. How long will you be gone? Maybe just shock, cover and run the pump. Hope for the best if you can't get someone to come over. If its short term, my guess is the pool won't suffer much except lower chem levels when you return. Keeping debris out of the pool with the cover on will help.
    giroup01 is offline Registered+ Thread Analyst giroup01 0
    Canada
    Default Re: Pucks
    Quote Originally Posted by jrv331 View Post
    John
    Try piercing a tiny tiny hole in a jug (or a few) filled with bleach and leave it floating. It may dispense enough to get you through.
    Reseller of Taylor water-testing products for Canada
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Default Re: Pucks
    Quote Originally Posted by NWMNMom View Post
    That's what I do, a 1.5 gallon jug of Clorox and I'm good for 7-9 days.
    Default Re: Pucks
    There are two types of Cal-hypo tablets that do not add CYA to your water and are supposedly slow-dissolving. Both are sometimes called "Duration".
    One is wrapped a plastic capsule that you then dispose of. Get this type.
    The other is not and will dissolve in a skimmer in a matter of hours, and block the skimmer...Guess how I know! Don't waste your time or money.
    HTH used to make the plastic type but now makes the caplet. There is a sister brand that I can never remember the name of that makes the plastic capsule.
    Again, that's what you want, that plastic-wrapped Cal-Hypo capsule.
    Default Re: Pucks
    Looks like I'll have try this method, Im going to be gone for 8 days so if I do nothing I will definately be at 0 colorine by the time I get home. Im leaving my solor cover on to keep out as much crap as possible.
    Back to the Tablets - I should know this, but whats the difference between dichlor and trichlor? I thought one was not stablized and the other was?
    Thats the reason I like the BBB method - simple and easy to understand.
    Thanks for all the help
    John
    Default Re: Pucks
    Almost all the tabs are Trichlor now AND just recently a lot of them have copper in them as well. The dichlor tabs are around some places but not anywhere I have looked recently (and I HAVE looked) The difference? Ummm...I know this one but it escapes me. Two vs. three (di vs tri) chemical compounds/active ingredients - the chlorine, buffer (cya) and other ingredients like copper (to act as an algaecide) not counting the inactive filler crap some have. Thats my best guess off the top of my head, but I bet if we look it up on the site, its here somewhere. Chemgeek?
  1. Floater pucks VS Skimmer pucks
    By ThaSatelliteGuy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-16-2011, 07:11 AM
  2. HTH 3-in-1 pucks
    By JBfromNJ in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-01-2007, 08:43 AM
  3. PH and pucks
    By aguaguy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-15-2006, 12:37 PM
  4. Do pucks get old?
    By Deuce2 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-27-2006, 10:03 AM
  5. pucks?
    By pairadocs in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-25-2006, 03:21 PM
