Thread: Calculating pool water volume
    Mandeville, LA, USA.
    Default Re: Calculating pool water volume
    Just averaging the shallow and deep end depths is usually close enough. In your case, (3 +8)/2= 11/2= 5.5 or (3+8.5)/2=11.5/2=5.75.
    So if the deep end is 8 feet you have, 18*42*5.5*7.48=31,101 gallons.
    While if it's 8.5 feet you have, 18*42*5.75*7.48=32,515 gallons.
    Honestly, you can probably just use 30,000 for simplicity's sake and be just fine.
    Rock Tavern, NY
    Thanks Kurt - that's been what I've been assuming. Appreciate the confirmation!
  1. Pool Volume Estimator
    By AnnaK in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-29-2011, 09:08 AM
  2. Pool Volume
    By isdsms in forum In-Ground Pool Construction and Repair
    Last Post: 09-17-2007, 12:23 PM
  3. Determining pool volume
    By KirstenHW in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-19-2006, 10:50 PM
  4. h2o volume of my pool?
    By dhale63 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-11-2006, 12:56 PM
