Thread: High stabilizer and help with chemistry please
    Cleveland, TX, USA.
    Question High stabilizer and help with chemistry please
    In the last week our pool temps have jumped way up and now my chemistry's all out of whack. First of all, my stabilizer is high...is there anything I can do to bring it down other than partial draining? If my test is correct it is at around 90 to 100. Also, too low chlorine levels- 0. I just turned my production up to 50% yesterday...should I increase it even more? My pH is high...just added acid and my salt level is low. I added acid this morning. Would it hurt to throw in a gallon of bleach this afternoon and then add salt tonight (I know I'll have to set the chl to 0% for 24 hours)? I don't know if doing all this in the same day could UPSET my pool. One last question, pool temp is about 85 during the day...what should I have my production set to and how long do you think my pumps should be running per day.
    Oh one more thing...how does your CYA get so high anyhow? Everything was perfect early last fall. We ran our pumps about 4 hours everyday throughout winter. I've never added anything other than bleach, acid, and about 40 pounds of salt.
    Sorry so long, but I'm still a pool newbie. Thanks for all your help
    Katy, TX
    Default Re: High stabilizer and help with chemistry please
    Hard to give you any sort of suggestions without knowing your actual test results, or the size of your pool.
    Ft Lauderdale, Fl
    Have you been using a granular tri chlor for shocking purposes or supplimenting with chlorine tablets? Both have stabilizer. There is other form of chlorine with stabilizer, Di-Chlor.
    There's really nothing else that would increase the stabilizer levels.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
    Cleveland, TX, USA.
    Smile Re: High stabilizer and help with chemistry please
    Nope, haven't used either.
    I added acid this morning, so my pH should be good now. I normally add a gallon every other week or so. I think I'll start adding a little acid each week instead of so much at one time. I also added a gallon of bleach, turned the SWC to 0% production, and added about 40#s of salt to reach 3.0ppm...it was at about 2.8ppm. Now I'll run the pumps for 24 hours and see what happens. It probably won't do any good to get my water "professionally" tested right now, but I might run a sample by tomorrow and see what reading comes up for my CYA. I also need to get a better test kit.
    I have an Aquapure SWC - they suggest 75 for the CYA. So if thats the case, I'm not too far off. The other posts I've read were keeping their CYA at 40-50ish.
    Also, any suggestions on what my chlorine production and pump time should be set to? I have yet to find a chart on this. My water temp is about 84 and I'm only running it for ~4hours each night. My production was set to 50.
    Thanks again
    Katy, TX
    Quote Originally Posted by shebert73
    Well, since you still have not given us any valuable information about your pool, it's anyone's guess.
    Michael
    Cleveland, TX, USA.
    See the first post. I'm not sure what else you need. I gave my stabilizer, chlorine, pH, and gallons - what else? Be easy on me - I'm new. BTW-my pH is now at 7.4 - it was at 8 or above at the time of the first post.
  1. First year pool high stabilizer and algae
    By ksherman in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-14-2013, 08:35 PM
  2. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 05:47 PM
  3. high pH chemistry
    By psanta33@gmail.com in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-14-2012, 01:41 AM
