Results 1 to 10 of 12
Thread: Too much DE added to sand filter
    Western Pennsylvania
    Default Too much DE added to sand filter
    Per the awesome tips from this forum I added DE to my sand filter. But I am positive I added too much, too soon. Since the water is too cold for me to get in and feel exactly what it is on the pool floor, is it possible the excess DE flew right through my filter and came out the return, to settle on my pool floor? Also, I took my filter apart to spray out the sand as I realized, after four days of my pool not getting crystal clear, that I had a 3" layer of muddy silt on the top of my sand bed in the filter. Is it possible I didn't get most of the excess DE from the sand and it's blowing back into my pool? My filter looks to be in great shape inside, I don't feel anything is broken. Any help or insight is appreciated.
    Default Re: Too much DE added to sand filter
    Did you backwash the filter at any point?
    You must first backwash before adding the DE.
    Then, if you add too much, you simply backwash again to clear it out, then add LESS DE.
    Honesdale PA
    Don't forget the RINSE cycle too. Rinse is just running the filter in the right direction but dumping to waste. Gets rid of any stuff in the pipes left over from the backwash. 30 seconds max is fine. I do maybe 10-15.
    Thanks a bunch guys! Now one more question, since I know where I definitely went wrong with adding the DE. Could that be the material on the bottom of my pool floor, it's only gathered in the couple wrinkles or so I have there. It's a whitish/beige color. Being that I put too much DE in, could it have flowed back out the return? TIA!
    Honesdale PA
    Almost anything is possible but I would suspect adding too much DE would just plug up the filter and the pressure would really climb. Since you have been inside messing I guess some DE could have gotten past the sand. What about pollen or silt as the stuff on the pool floor? I've had both. Fine silt kicked up when filling from some wells may pass the filter as could pollen. My pollen, and I believe this can be a general statement, has a yellowish color and may be hard to tell from silt unless you look at it under a microscope. Silt looks like fine, beat up sand and pollen has a very regular spherical shape. DE in the sand filter should trap both but the easiest way to eliminate would be to vacuum to waste.
    Edit: Check these threads
    http://www.poolforum.com/pf2/showthread.php?t=6799
    http://www.poolforum.com/pf2/showthread.php?t=6744
  1. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
    Last Post: 05-30-2007, 11:01 PM
  2. Red Streaks From Sand Added To Concrete?
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 10-12-2006, 08:27 PM
  3. Added DE to sand filter. Now pool is full of DE.
    By les_smith in forum Pool Equipment & Operations
    Last Post: 08-17-2006, 07:16 PM
  4. Added DE to Sand Filter, 1 cup didn't raise PSi
    Last Post: 06-28-2006, 11:39 PM
