Hi Sean,
I think I can handle checking that fuse. The connections look like new... I checked all of those at first.
I called and left you a message.
Thanks,
Sonnie
Hi Sean,
Thanks,
Sonnie
Mine is doing the same thing, its only a 1 1/2 years old. Called autopilot, they were suppose to call me back today, still waiting.
Well fortunately I found the problem with ours. It was a bad banana plug connector. When I took the cover off looking at the fuses, I also looked very close at all the connections... just basically tracing all of them down from outside to inside to see if maybe something was loose. I got to looking really close at the banana plugs and noticed the black one had a bubble on it, as if it had gotten hot and melted. So... out comes the ole trusty test meter and sure enough there was no contact from the black cable outside the box to the terminal inside the box. Unfortunately I did not have an extra banana plug lying around, so I hard wired the red and black wires to the inside, bypassing any banana plug connections. I suppose if that cable ever goes bad, I'll simply have to hard wire it again.
Below is a link to a pic of the banana plugs... apparently a bad solder on the inside of the plug shorted it out.
$30 worth of algaecide, $5 worth of bleach and a little jury rigging later, we are now functioning normally.
26V 8.0A
No more "Low Amps - Cell" warning.
Sonnie
I wish that was my problem, Its not I just checked it.![]()
Did you check the fuses? There appears to be three underneath the cover.
As Sean suggests though... make sure you turn the power off before taking the cover off.
Checked the fused all okay. Sean is getting a service call put in.
