Thread: How much sand to use in sand filter?
    Default Re: How much sand to use in sand filter?
    Even the 20-21psi??? Before the solar heaters, I would let it go to 19-20psi, then I would backflush. What pressures would you let it rise to, before backflushing?
    Kansas
    Hey PorkyPete-
    Can I ask you a question?
    How was it when you went to connect your 1 1/2 black plastic pipe to your inlet and outlets on the solar panels? We tried to do the samething yesterday but that black plastic pipe is so hard it wouldn't crush tight under the clamps where we connected it to the solar inlets/outlets. We are going to have to find something to make it work. Did you have that problem?
    ~Hoffmans
    I ran 2 lengths (35 ft.each) of that 1 1/2" black poly pipe (that comes in 100ft.rolls) at the base of the pool. I pushed in "barbed fittings"(76 cents each) which allowed me to use regular pool hose (and clamps) between the pump (or solar heater, etc.) and black poly pipe.
    Honesdale PA
    A heat gun works well to soften the pipe to let it slip over the barbed connections easier and form a better fit when you tighten the hose clamps. Electric paint strippers are cheap too. I've also used a propane torch but you have to be more careful not to burn the pipe.
  1. Sand Filter dumped all the sand in my pool
    By ib_gman in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2012, 12:16 AM
  2. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 10:41 PM
  3. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 08:36 AM
  4. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
    Last Post: 05-30-2007, 11:01 PM
  5. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 12:01 PM
