Results 11 to 14 of 14
Thread: Pump timer
    Jul 2006
    Default Re: Pump timer
    Hey Jeffski, is yours an electronic ignition Mini max or Millivolt? Mine is a minivolt I am pretty sure it doesn't have a fan... since there is no power going to the unit to power one.
    Is there anyone who has a minivolt setup that can take a picture of their timer and setup?
    Have you tried contacting Pentair (1-800-831-7133)?
    I figure there has to be some kind of a device to connect between a typical timer/fireman switch and the thermostat board.
    *** Don't try the following at home ***
    It seems like a transformer to step the voltage down and then a low voltage relay should do the trick. But this is normally where someone jumps in with why didn't you just buy X instead of doing that? Actually you'd want to change the voltage to DC to reduce the chances of inducing a current in the low voltage line due to magnetic fields. I'd still be somewhat concerned that voltage spikes could be sent when the relay is tripped.
    Yep, mine is the Mini Max and has an electrical connection.
    Jul 2006
    I called pentair and they told me that the tech dept has repeatedly told them (sales and customer service) that all their heaters do not require a cool down period... now with that being said, they told me that the tech dept will call me back in the next couple of days to confirm this.
  1. New timer with new pump?
    By tessaduncan27 in forum Pool Equipment & Operations
    Last Post: 06-08-2013, 10:30 AM
  2. Question about heat pump pool heater and fireman's switch on pump timer
    By HuntnHog in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2011, 08:37 PM
  3. Pump timer
    By CoffeeBean in forum Pool Equipment & Operations
    Last Post: 03-20-2010, 12:53 PM
  4. SWG and pump timer
    By doriec in forum In-Ground Pool Construction and Repair
    Last Post: 05-27-2006, 10:41 AM
