Sorry it took so long, but here are pictures of the pool and deck. I'm having some algae problems right now so the water is kind of cloudy.
I've still got a bit of work to do on the deck, like framing out the underside, putting lattice up for additional storage and some staining but it's pretty much finished.
My deck posts are set well below the frost line so I don't expect any heave on the deck. The pool, being buried 2+ feet in the ground hasn't moved over the past 2 winters (I measured several times a week against a fixed point on the house) so I'm keeping my fingers crossed that I wont have any problems with the rails sitting on the deck surface.
Your deck looks fantastic, its pretty close to how I want to finish mine. Can you tell me if you got the plans off line or did you do them your self - Im really interested in how you did the rounded portion around the back.
John
We did the deck on our own, with no plans. Once we placed the pool, I took spray paint and sprayed the general layout of the deck on the ground. That gave me a good idea of how much space I would actually have.
The "round part" is not really round. We simply put a deck post at every pool support, measured out 4 feet from that post and planted the outer post in the ground. Although each section is straight, the end result looks round, much like the rails on a pool.
Quick question on your deck. How close is the bottom of the floor board to the top of the skimmer basket. Im going to be finishing my deck this weekend and from a preliminary look, it looks like my boards will be about an inch above the basket. This kind of worries me that a board will have some play and crack the skimmer.
John
My skimmer basket is a couple inches below the decking. I cut out the decking above the basket and add two pieces of wood to the bottom of that decking to hold it together and maintain proper spacing.
I then screw in support pieces underneath the deck to support the wood I cut out.
See the pics below and it will make more sense. I've had a couple of decks and always solved the skimmer issue this way. Kids will run across the skimmer and this method ensures that there wont be any accidents. It looks good too.![]()
